Use the following procedure to display the MSDP peer information for a specific RP. The SA messages are received from the MSDP peer.
Switch:#enable
Switch:1#show ip msdp rpf 172.16.10.13
                          MSDP RPF - GlobalRouter
RPF peer information for (172.16.10.13)
RPF peer: (172.16.121.10)
RPF route/mask: 172.16.0.0/255.255.0.0
RPF rule: Peer is IGP next hop of best route
RPF type: unicast (ospf)
Variable definitions
The following table defines parameters for the show ip msdp rpf command.
| Variable | Value |
| {A.B.C.D} | Specifies the RP IP address. |
| vrf WORD<0–16> | Displays configuration information for a particular VRF. |
| vrfids WORD<0–512> | Displays configuration information for a particular VRF ID. |
